Hello,
I fitted two Crucial 128GB M4 SSD's to machine with the following spec:
Asus P8Z68 Deluxe Motherboard (not GEN3) - BIOS V 3203
12GB Corsair Memory
Intel Core i7 2600
Nvidia Quadro 2000D
Seagate 1TB HDD
The Crucial SSD's replaced a Corsair Force 3 120GB drive. The objective was to place the SSD's in RAID 0 and create a boot disk for Windows 7 Professional x64 of approx 240GB.
Windows installed succesfully but things were not right. When installing drivers I would get random decompression errors, running the driver install for a second time it would install OK. Then some Windows Updates would hang for approx 20 minutes and only a reboot would get it moving again.
Later on in the install process the blue screens started, they would mostly occur when installing software or anything that required a sudden amount of data to be read. It occurred once when opening the event viewer.
I checked the firmware on the SSD's and found it to be out of date, so upgraded to V000f via a boot CD. Both were flashed OK. Blue screens continued. The motherboard BIOS was updated to V3203, blue screens continued.
Deleted the RAID set, created it again and installed Windows again, I have not yet had any blue screens but software that installed successfully will not install, still have issues with windows updates hanging. The software installs fail with random errors, mostly about being unable to access a file.
Something is not right, any suggestions as to why this hardware configuration might not work? I have previously used the same SSD setup but with the P8P67 board and it works great.
Thanks
12GB Corsair Memory
Intel Core i7 2600
Nvidia Quadro 2000D
Seagate 1TB HDD
Thanks
