What mousemat/gaming surface do you use? (pics)
+1 for the Boogie Bug, I've used expensive razor ones and the Boogie Bug is just as good, if not better.
Not to mention half the price and double the size.
Yep,and Puretrak Stealth. ;) Same surface, different colour, slightly smaller.
I don't suppose you know where to buy Puretrak things from in the UK? Emai me (in trust) if it's a competitor. I need a new Talent for when my ones gets too old, but I don't want to play £20 for shipping from the US. :x
Is there anything similar to the boogie bug but not very deep?
My desk isn't very deep - my case just about fits on top so the boogie bug would be too awkward with all my stuff on the desk.
I would like one though as I think they look very neat, so is there something that fits my needs?
Just seen what I'm after, razer goliathus extended...looks like a very long bar mat lol.
People have been known to cut it to size.
Those Boogie bug XL keyboard/mouse surfaces are rubbish. I fell for the hype when they was in serious demand and out of stock on OcUK last year, and within a month the smooth material part of the surface started to come apart from the foam base. So i went back to using my Steelseries QcK SC2 Marauder Edition mouse pad. :p
Had mine almost a year now and even where my arms rub against it its still in one piece. I use it with my MX518 and have no reason to change.
Razer Lachesis and a granite floor tile ;)
Soz for poor camera qulaity :P
I just can't seem to get my mousepad right. I have a coolermaster xornet mouse and use it on a boogie bug XL, which is rubbish as there is far too much resistance. I then bought a Qck mini and again too much resistance! The only pad that enabled it to move smoothly was a CM STROm battlepad H2 but it is too small.
Can anyone recommend a large, very very low friction mouse pad? I was looking at razer sphex.
Cheers.
