Who offers best FTTC
10 Mar 2009
Newark
I have placed an order for BT infinity but not sure if i made the right choice, paying £20 for first 3 months, then £26. I use a lot of torrents and dont like the idea of being throttled coming from BE and no throttle at all. Who offers the best fibre at the moment in terms of usage and throttling?
On the other hand BT is not so bad with FTTC itself, they do throttle but not as bad as their ADSL products.
When you say throttle, for instance they say i can get 62mb download, so would they throttle me down to half a mb? or is it something more like 10mb? Just want to know how bad it is i can live with 500kbps-1mbps if they throttle down to that sort of download speed
Less than 100KB/s in some cases. The upstream throttling is particularly bad.
All on their website. So only bittorrent (and other p2p tech) gets throttled. Nothing else is throttled. Any other slowdowns are due to technical problems or congestion.
Do sky use the BT equipment or do they put their own gear in?
Yes and No.
From your house to your local cabinet, then from the cab to the exchange is all BTO (openreach), copper/fibre. Hence why BTO come to install and not a sky engineer.
Sky use there own equipment once the line is at the exchange, and they use there own backhaul (main line) from exchanges to their base for broadband (think its in london somewhere). No idea if they physically own that backhaul or if it is long term leased from other companies though.
The only thing with me is I don't want to change my phone number and sky make you do that. So SKY have a presence at my local exchange does this mean I can get FTTC off them? I have no idea with FTTC as I'm used to the way adsl works!
