Ive just ordered BT infinity which should be installed on the 17th. I'm told I should get 72 down and 20 up which should be good. The cabinet is only about 100m away.
I've heard that the BT home hub is not that great so I'm looking to get a better router. I would also like a router which will act as a VPN server so that I can connect in when I'm abroad to get a uk ip address for iplayer.
What would you reccomend? Would want to spend between £50-100.
