- 30 Dec 2003
- Scotland
Hi, I am pretty much a n00b when it comes to all things mechanical, however know a few vasics about brakes etc. I was thinking about looking at my missus' rear brake pads (just been done not long ago) to see what the possible rattling is that seems to be related to the drivers side caliper.
The main question is this, do I if only taking the pads out to check the caliper, have to use a caliper rewind tool to reset the position of the caliper if I am just checking and not changing the pads?
Secondly, has anyone had issues with brake cable rattles or is this likely to be something more meaty attached to the brake calipers and pads causing the rattle?
All help would be gratefully appreciated.
Ta.
Ta.
