FREE BitFenix Spectre Fans - Big Silence Test
In my Shinobi Window case I have 2 plain black spectres, 2 blue led spectres and 3 very loud cheap blue led case fans that are getting right on my ****.
I have looked everywhere for replacement blue led spectre fans and cannot find them! I would like to upgrade to the pro versions but family comes first :P
I would like 3 120mm spectre blue led pros to see how they effect my cooling, see how noisy they are (i want a silent system) and finish off my whole bit fenix rig!
@CinderzFTW: OCUK will have new stock of all our fans by next week I believe.
@BloomerzUK: Thank you for the first pictures... Could you make a own new post once in the General Hardware forum once you write up your test?
2 days and mine will be up, Excited to have a play with them. If i don't get the Hydra are the LED Cables able to be joined up to a switch and run that way? I love LED's but i like the idea of being able to turn them off also.
im using 2 coolermaster megaflow 200mm reds at the moment.
would be nice to see what the brightness difference and sound is compared to these.
megaflow's in my opinion are amazing fans though very quiet and very good LED be hard to find something to beat these.. :P
If i was to win i would want 2x 200mm Red LED
Competition finished.
I think Kul1 or a mod should edit OP to say Comp ended in larger yellow letters.
The 140mm fan isn't going to fit my graphics cooler properly so that's rather a shame. I must have got the fan models mixed up and seen another Bitfenix fan with 120mm fittings.
I'm working today and am away over the weekend so hope to spend a couple of hours on Monday or Tuesday doing some kind of review comparison on the fans before I butcher them and add a few dozen LEDs to them and sleeve the wiring.
The 140mm does have 120mm mounting holes.. You're using a Shaman?
Mine doesn't. And yes I'm using a Shaman. Mind you I haven't checked it for fitting yet but know that the TY-140 I have on there is 120mm fittings.
I suppose I could always drill them :)
-snip-
Ahhhh. My bad. The Spectre's don't have 120 mounts on the 140's. The Spectre PRO's on the other hand, do. My mistake in interpretation!
Unlucky on the size problems, I hope you can modify them. I do want to see these modified with LED's though the white fans look amazing! Shame im not going for that look tbh as black and white is amazing.
