UAC
Caporegime
5 Nov 2010
Hertfordshire
(Windows 7)
I have so many program's that require me to 'OK' UAC to run. Therefore I have disabled it. Being a competent PC user and not a moron that clicks on every thing that wants to install itself, I should be fine.
However, is there an easy way (without task schedular) to disable UAC on selected applications?
Being a competent PC user, I should be fine.
If only life were that easy
As a side note to the above post, I still don't understand why java only updates once a month. Java 7 has only just come out and it's on update 4 already. I'll bet 90 odd percent of people on here haven't changed it either.
Java gets patched rapidly but doesn't bother to update itself - doesn't make sense (but does explain why it's such a big security problem).
Im a bit miffed as to what you are running that requires admin privileges so frequently?
Prime95, CPUZ, IBT, most overclocking utilities will ask for an 'OK' before running. Fresh build of Windows7 64bit Ultimate, so it's not like anything has be screwed up.
It's frustrating. Monthly update checks and lack of auto-update make it a recipe for disaster. I'm hoping they'll copy Adobe & Mozilla by adding a system service to get around the UAC issue.
The Java entry in control panel doesn't seem save changes if UAC is enabled. The auto-update frequency reverts to monthly after I change it to daily. Do they really think we're all running XP with a local admin account? :confused:
EDIT: Just installed Java 7 in a VM. It looks like it's once a week. Maybe we're making progress?
EDIT2: A way to change the automatic-update frequency with UAC enabled. Control Panel > Right-click Java > Create Shortcut. Open an elevated command-prompt. Navigate to and open the shortcut. Make the change. :)
Clicking YES is effortless.
In principle no, since otherwise it would rather defeat the point.
EDIT: http://forums.overclockers.co.uk/showthread.php?t=18401358 see this thread for an example on why we like UAC among other recommended security measures :p
The OP in that thread doesn't want anti-virus installed so it is hardly surprising he has become infected with something. I have UAC turned off all the time because it bugs the hell out of me but I run decent anti-virus and firewall (plus other things) and never had a problem.
Stoner81.
Comparing UAC to anti-virus is like comparing apples to pears, they exist for different reasons, and one doesnt trump the other.
UAC's job is to verify with the user that the requested administrative action is OK to proceed with. If you ever had a WinXP machine a few years ago, before UAC, and something or someone had managed to compromize security, they could make changes as you without you ever knowing.
Then add to that, it protects against accidental changes that you might not have intended to make.
Finally, it virtualizes file/registry writes to protected areas in the filesystem/registry. This helps legacy apps run in a standard user context (Im guessing you are logged on with admin rights, so this is less of a concern for you)
All in all, its one click on Yes - hardly much of a bother, is it?
Stoner81.
To some extent see stealthgeek's post. Vista shifted gears entirely with respect to security in a way that makes xp look incredibly outdated, and UAC is a very important part of that, in particular in terms of namespaces and access rights.
A large number of people had no problems running xp when they just had a antivirus and firewall running. That doesn't mean that there's no more one can or should do to help protect your system. If the worst should happen, there's a lot more you can do now to minimise the damage than before. Fair play to you if that works for you, but I'm personally happier with my setup and having to occasionally put in a password for admin rights. :)
It gets old very quickly.
'Yes, D3Doverider is fine to start at boot' (as it has been the past 100+ times!)
'Yes, I know what Steam is, just let me on my games'
'YES I DO WANT TO LOAD CPU-Z THAT'S WHY I CLICKED IT'
etc. etc.
UAC is a complete pain in the behind.
AV doesn't not offer protection. The OP is not infected. He should really know better considering he works in IT.
Random botnet. How many different AV clients do you see listed?
UAC only intervenes when Steam wants to install a game.
CPU-Z is requesting additional privileges, hence the prompt. It isn't a simple "are you sure you want to run this application?".
UAC prmopt are a royal PITA.
Off the top of my head, Afterburner, D3DOVerrider, MalwareBytes, Ccleaner, RealTemp, CPUZ all require a yes click before they'l run, bloody annoying on such frequently used and safe programs.
