When you put the car into neutral, it is the same as having the engine running while stationary.
If you are moving downhill without touching the accelerator, then the motion of the car is turning the engine, and uses very little fuel to keep it running.
Even just going along on a flat surface probably switches off the fuel injection until a certain point - the difference in engine braking force vs coasting braking force (i.e. rolling/air resistance) is caused by the resistance of the pistons and driveshaft.When you put the car into neutral, it is the same as having the engine running while stationary.
and in some cases, no fuel at all.
I hope I don't sound like a pedantic **** but in which case does it use no fuel at all?
Why not just use the clutch to coast instead of using neutral? You can always move into gear and accelerate when necessary?
Doubt you'd save much though unless it's downhill all the way.
I was told that over around 2500rpm, if the throttle is closed, no fuel is used as the motion of the car is keeping the engine turning over. In neutral, fuel is required to keep the engine running.
A guy I lift share to work with coasts downhill all the time, really does my head in and is quite scary at times :|
Why is it that scary though? Assuming he keep his speed in check is it really that different to being in gear?
