Who has bought the Nvidia 670 cards
Goods Shipped:
£299.99 x 1 - KFA2 GeForce GTX 670 EX OC 2048MB GDDR5 PCI-Express Graphics Card
Going to be sat with this thing on my desk at work for several hours, watching the day tick slowly away :rolleyes:
Any solid news if these have the adjustable voltage chips?
Cant say tbh. On an aside, id noticed that it use an 8 and a 6 pin pcie connector. Just double checked my HX850 psu, 8 pin connectors throughout, and ive found the blue braided bitfenix 8 pin pcie cable i mistakenly bought. Knew id end up needing it someday. Will tone in with my current 6 pin ones.:D
Apologies pgi as I moved what I was asking so sorry for the confusion :D
As everyone was talking about their new purchases I didn't want to go off topic.
Ahhh, you managed to confuse the life out of me :p
Damnit, I need to order some blue/blue 8pin pcie Alchemy extensions, should blend in nicely with the PCB, have 4 6pin blue/blue, looks like 2 of those are going to go on the MM.
Got a KFA 670 (non-OC) coming tomorrow, but I've ordered a Gigabyte Windforce x3 as well from a competitor for nearly the same price, so will compare the 2 & decide which to keep.
Does a reference design really need comparing to the Gigabyte windforce :p
Just ordered me the KFA2 oc, been contemplating the 680 or 7970 for a while but i think for the price your not gonna be beating these :)
Shapping up to be good cards. So tempted to scratch my upgrade itch, but I think i'll wait just a little longer unless someone can persuade me... SOMEONE PERSUADE ME OVER 2x 460's xD
Buy a 670, sell 460s!
Should still be worth £80 each if they are 256 bit versions.
They are both 256bit versions :) highly overclockable aswell, have them stable @ 775/1550, although one has two broken fan blades :(
Yea get a GTX 670 now and sell those for £80 each if you want. Get yourself a nice KFA2 or Gigabyte too while you can.
I thought it would be a lot more than 30%. I can't justify selling a GTX 480 for £110-120? And spending a extra 200 for a 30% boost. Hopefully the AMD card's prices fall significantly as I'm happy with the 480 performance just want a cooler running card.
*Cough*
Sorry to be picky about maths but technically if the GTX 480 is at 72% and the GTX 670 is 100% then the GTX 670 is 39% faster. (100/72 = 1.38888).
Granted that's still not a lot more than 30% but 39% faster sounds better than 28% faster.
(as a side note if you compare the 480 and 680 performance at 2560x1600 then it shows a 52% speed increase over 2 generations which doesn't sound like all that much but then 400->500 series wasn't really a massive change.)
It's a bit more than 30%. The graph shows the gtx670 at 100% and the 480 as 70% of the 670's performance. 100/70 = 1.43 times a gtx480's performance so it's 43% better roughly.
Edit: ah **** beat to it by the man above whilst I was typing and calculating :P
