Something that thick I think will be too thick - I am expecting about 1-2mm of clearance here![]()
rossi, i know this is going to be hard to tell, but if you had a gpu in what would be the top possible slot (probably a 1xpcie on your board) do you think that the phanteks would block that slot?
Got 3 coolers in my basket (ND14, Thermaltake Frio Extreme, Phanteks) and at this point think I might just buy al 3 and hopefullt find one that fits.
Am pretty sure the ND14 will fit, but really want the phanteks
can i put 120mm fans on phanteks?
.The top slot on my board the pci-e with the Matrix in it. However the case has a slot higher. If that slot was able to be used then i think would be very close.
And yes you can attach 120mm fans to the Phanteks, uses clips for the fans and the fans themselves have 120mm hole spacing.
My Phanteks should be arriving tomorrow for my R2 install. Will let you know when it's installed![]()
Oh no....
Place I ordered from has 11PM cut-off, which I was well within when ordered. Looked this morning and it says "picking in progress"
If this is accurate, then not going to get anything until at least tomorrow. This may not seem like a long time, but I really really really want this done and dusted now
Hope their site is wrong.
