Why 3 fans?
Also, you need 7/16 compressions.
Oh 3 fans, 1 spare (might stick in spare PC as a fan stopped)
Oh yea thanks
If you put the cards in slot 1 + 2 you will be using the nf200 .. surely best to use the recommended slots 1 + 3?
I probably will, still thinking about the cards
from what I read its better to have the cooling in parallel on the gfx cards, suppose to run em slightly cooler that way rather than having 1 running hotter than the other but would be only few degrees in it either way , but people have different opinions on it either way.
as for the compression fittings , as cleeec says u need 7/16 compression fittings , from personal experience the Ocuk compressions I couldn't get em to fasten at all and the EK ones wasn't much better with less than a turn before they locked , not tried bitpower ones but I read they suppose to be better fitting but ofc cost a lot more , prefer 1/2 inc barbs myself with 7/16 tubing(nice tight fit and no leaks)
Hmmmm thanks for the info, I still could notmake my mind up with the barbs or compressions fittings, it just seemed to me that teh compression might look a bit better? currently the only ones in stock are EK PSC Compression Fitting 7/16 [16/12mm] - G1/4 - Black EK PSC Compression Fitting 7/16 [16/12mm] - G1/4 - Black. Might be something to think a bit more on, or could just get some barbs and compression fitting and see which I like the most?
