Im having a little issue with Heaven 3.0 crashing after about 10 minutes. reporting that the display driver had to be restarted. I was watching it run and the temperature never went above 72c and there was no artifacting.
I also had Saints Row the third crash today with me today just with a not responding error which has never happened before.
I ran heaven for well over an hour last week with no issues I was also playing saints row earlier in the week for around 3 hours non stop.
The only change ive made since then is ive changed my cpu cooler but its definately not overheating.
Ive done IBT on maximum for 10 passes and run prime for 18 hours again without issue.
My PC spec is below
i5 2500k @4.5ghz
8GB Samsung green
Asrock Z77 Extreme 4
SLI GTX470 @800mhz core and stock mem 1.025v
1x GTX 470 MSI twin Frozr II
1x GTX470 Gainward Good edition
XFX PRO850W Core Edition PSU.
Now when i run my cards at stock clocks/volts the fault goes away but wheres the fun in that?
The cards appear to perform faultlessly right up until the point they I get the crash. Im wondering if this could be a power issue? Surely my 850w PSU should be enough to power this set up unless its on its way out?
Can anyone offer advice on this?
Thanks
Scott
My PC spec is below
i5 2500k @4.5ghz
8GB Samsung green
Thanks
Scott
