"This computer does not meet the minimum requirements needed to xxxx"
I got this message several times using the installation files on the CD.
No idea what's causing this.
If you're using the integrated GPU then I don't think any of the outputs on the motherboard will support 2560x1440.
- 1 x D-Sub port
- 1 x DVI-D port, supporting a maximum resolution of 1920x1200
* The DVI-D port does not support D-Sub connection by adapter.
- 1 x HDMI port, supporting a maximum resolution of 1920x1200
If you're using the GTX 670 then make sure to connect with a dual link DVI or DisplayPort cable.
