680 2gig v 680 4 gig
Shouldn't be a problem as i got the cards on try before i buy,have had nothing but probs with this build sometimes wish i never started. As they say good things never come easy.
Worth sticking with as it is a real nice rig you have :)
Patience is the best and hope all cool at the returns.
glad you got it sorted :)
Thanks,
I got the choice of two new ones or waiting for the 670 4gb version. I took the first and got two new Jetstreams , only time will tell if I made the right choice.
My results are getting better as 1 of the cards wasn't working fully,it's great playing BF3 3screens with nearly all maxed out at over 80fps. So what will be interesting is if the 670 4gigs preform similar, so now to clock them to see if things improve.
The guy has 2x680's so the ram shown is doubled. He is infact using 1250MB max
i thought that was amd cards that did that, on nv cards it shows correct, the poster has 4gb cards
I show 1400+ even on first load on that map at 1080p so I'm pretty sure he'll be using more than 1250mb at 1600p
Thanks,
Now the 4GB 670s are due to be released in the coming weeks the extra £200-£280 (£400 for 4GB 670s each £540 for JetStreams) for those 4GB JetStreams would make me lose sleep as the 670s are really not far off a 680 and that's a huge difference in price.
