ASUS P8Z77-V DELUXE & AMD 6900 ?
20 Jan 2009
Simple question I have here >
Will the ASUS P8Z77-V DELUXE GEN3 motherboard be able to take the massive sized AMD 6900 graphics card without any problems at all such as not fitting in firstly or fitting but effecting some connectors on the board etc ?
Appreciate any comments.
thanks very much. :)
p.s
I already looked on the internet for the answer and cant really find the answer.
If you look at the mobo, the only thing it will do is cover one of the Pcie 1.0 slots. If it fits on P67 and Z68 boards, i don`t see any reason why it won`t fit a Z77 board. I would be more worried about it fitting in your case.
thanks,
the board it is on just now without a problem is the msi x58 platinum and the case which I will be keeping and using that it fits into fine is the HAF 932, does that help you anymore with those extra details please ?
(just not sure about the asus board that I mentioned, thats all :()
•Processor: Intel Core i7 3770K
•Motherboard: ASUS P8Z77-V Deluxe
•Memory: 4x4GB Patriot Division 2 1600MHz Dual Channel
•Video Card: Intel HD Graphics 4000, Nvidia GeForce GTX 680
•Hard Drive: Patriot 240GB Pyro SSD
•Power Supply: ThermalTake Tough Power Grand 1200W
•Media: ASUS Blu-Ray DVD
•Operating System: Windows 7 Ultimate 64-bit
http://www.hitechlegion.com/reviews...sus-p8z77-v-deluxe-motherboard-review?start=9
If the GTX680 fits, i see no reason why a 69** series won`t.
