- 23 May 2011
- Surrey
build a hobbyking 450 you can get all the bits minus the radio gear for around £150 or less.
buy a cheap radio to start with on the hobbyking site for around $25 like the HK-16a 6 channel radio (ive got one and it works great just a pain because you can only alter all the trims and throttle curves with a pc)
the larger the heli the more stable and less twitch they are, i started with a 250 clone but wish i went with a 450 now.
theres a huge thread on the 450 clone here http://www.rcgroups.com/forums/showthread.php?t=1335980
ive been thinking of getting a flybarless 450
http://www.hobbyking.com/hobbyking/..._Tube_Helicopter_Kit_Align_T_Rex_Compat_.html
instead of a tail gyro you use
http://www.hobbyking.com/hobbyking/store/__20996__Hobbyking_ZYX_3_Axis_Flybarless_System_.html
Thanks for that.
So which 450 model would be good for a beginner? The flybarless 450 you linked to?
I put together a components list for that one and it's looking to be about £180 including shipping for everything including the Turnigy 9X transmitter.
Just a bit unsure of which model is best for a beginner as there are so many to choose from in the 450 model alone.
EDIT: These were the parts selected. I think the only other bits I would need are some tools and a charger?
Date: Fri, 11 May 2012 07:29:05 +0000
Quantity Stock Product description Price Weight
OK 155000030 - HK-450TT PRO V2 Flybarless 3D Torque-Tub.. http://www.hobbyking.com/hobbyking/..._Tube_Helicopter_Kit_Align_T_Rex_Compat_.html
*This item usually ships within 3 days $62.99 997
OK TR_P40A - TURNIGY Plush 40amp Speed Controller http://www.hobbyking.com/hobbyking/store/__2165__TURNIGY_Plush_40amp_Speed_Controller.html $17.80 79
OK TY2218-3450 - Turnigy Typhoon 450H 2218H Heli Motor 34.. http://www.hobbyking.com/hobbyking/..._450H_2218H_Heli_Motor_3450kv_450_class_.html $14.34 101
OK N2200.3S.25 - Turnigy nano-tech 2200mah 3S 25~50C Lipo.. http://www.hobbyking.com/hobbyking/store/__11911__Turnigy_nano_tech_2200mah_3S_25_50C_Lipo_Pack.html $13.43 237
OK HK-CS929MG - HobbyKing 929MG Metal Gear Servo 2.2kg/ .. http://www.hobbyking.com/hobbyking/...9MG_Metal_Gear_Servo_2_2kg_12_5g_0_10sec.html $13.53 99
BK 297000001 - Hobbyking ZYX 3-Axis Flybarless System http://www.hobbyking.com/hobbyking/store/__20996__Hobbyking_ZYX_3_Axis_Flybarless_System_.html
This item is on backorder* $49.80 159
OK 9297000002 - Hobbyking ZYX 3-Axis Flybarless System U.. http://www.hobbyking.com/hobbyking/...s_Flybarless_System_USB_Program_Adapter_.html $3.85 25
BK TX-9X-M2 - Turnigy 9X 9Ch Transmitter w/ Module & 8.. http://www.hobbyking.com/hobbyking/..._Module_8ch_Receiver_Mode_2_v2_Firmware_.html
This item is on backorder* $53.95 1289
OK BOX-439g - Extra Length Cardboard Box and Packing 4.. $0.00 439
TOTAL: $229.69 3425g
a lot have the boom aswell, oh and whats this why are all these trex converted to flybarless using hk heads?
