I really don't know if you are being ignorant on purpose or are taking the mickey, but if you think the mobo runs without power from a psu then maybe you need educating. Lol.
"Get the best GPU you can afford though. You really need this IMHO, as it will make a BIG difference when playing back 1080p in MPC (Media Player Classic) for example and you start adding shaders etc. Also helps with Blu-ray hardware acceleration etc."
and...
"Try and play a 1080p MKV with DTS HD Master Audio and add "Sharpen Complex" as a shader in MPC... it will drop frames."
So where did I say Llano was no good for Blu ray??
Regardless, anyone serious about building a HTPC will know about madVR and things like hardware deinterlacing etc. Llano just doesn't have enough grunt. Simples.
There doesn't seem to be that much information around about madvr. Could someone kindly explain a bit about what it does and what makes it so good for people serious about HTPC please?
