Amd A4-3420
7 May 2012
Bracknell
As a newbie to all this is it possiable for me to upgrde this cpu easy for something else on my motherboard.
Thanks in advance
Anthony
Oh ok i see what you mean now thanks, so is it as easy as taking out the old cpu and just putting the new one in ?
Anthony
Originally Posted by cplnobbie
What's the quick way to find my motherboard type pls ?
Anthony
Go to command prompt and type wmic computersystem get model
It should display the motherboard manufacturer and model providing the OEM filled this field in the bios.
Yes Oh it's an Medion desktop
Medion sell a desktop using the quad core A8-3820. So it's possible. Your best bet is to contact them and ask if your particular machine supports quad core CPUs before you go dropping money on a CPU and throwing it in there.
