if that is kinked it would make the flow bad i know you said it was fine and not kinking but take another look
like i said buddy its fine.
http://imageshack.us/clip/my-videos/694/eov.mp4/
This is my Flow. Thats a D5 on 4 it can go up to 5 so can get even more flow than that.
D5 is a great pump if you can fit it in.
(sorry for the bad quality that was off the phone)
I had one of those XSPC pump/res combos, and it broke, but the only indication was that my temps on all cards went up. The pump, despite being submerged was full of air, and ultimately the impeller broke. NO water was flowing.
The temperature on your GPU @ 50C is not particularly high if that is fully loaded, but if that is unloaded, then I'd agree that is VERY high and indicative that there is little or no flow round your loop.
Clamp off the hoses to your pump, and test that the pump is actually moving some water.
lookin at the video seem your flow is low
i would disconect the bottom rad from case move it around as much as poss to make sure u dont have an air lock
then do same with the top one.
before buying new kit
seems from what i saw the flow is low ..
this is a weird one tbh
i dont think u need a bigger res if the rads are full they do the cooling all a larger res does is gives you that little mor volume so the water takes longer to get to ambient
i have 2 x 250 ml res and a pump header tank and a 240 rad from a ek2,2 pump and my water is flying round
i think u may still have an air lock or a flow problem ( blockage)
temp on GPU is at full load overclocked under furmark
just done the top rad and its full, cant hear any movement of water at all. i'll try the bottom rad but there isnt much room to maneuver it around with the hose connected to the gfx card, gona rest the case on the front panel for a few hours
I usually achieve this by unplugging the rig, and hotwiring the pump so it is the only component physically powered up. Then I turn the case so the radiator I want to de-aerate is at the lowest point, ie tip the case upside down, so that any air rises into the reservoir. Looking at your case, if you were to roll it so that its on the back (there the io ports are) then this should achieve the same - as long as the reservoir is physically higher than the radiators. I then just leave it in situe for a couple of hours, and all the air usually comes out.
I doubt that's your problem though as your gpu is being cooled....
the pump/res combo is a cheapish 1,what XSPC do with there £99 single rad kit so if no air in loop just go for it invest in a better pump and new CPU block cos that is an old model
http://www.overclockers.co.uk/showproduct.php?prodid=WC-069-XS&groupid=962&catid=1519&subcat=
http://www.overclockers.co.uk/showproduct.php?prodid=WC-012-EK&groupid=962&catid=1519&subcat=
im getting 1 of those for my i7 3770k setup dunno which yet
I've rad good things about the EK Supreme HF. I'll see if I can dig out something...
