Anyway what did you think of results so far?
It was not your fault the badge fell off so shouldn't be a problem replacing.Shouldn't be a problem as i got the cards on try before i buy,have had nothing but probs with this build sometimes wish i never started. As they say good things never come easy.
I like the the jetstreams as they're so quiet and have really good coolers.
Back in the game with 2 x new, now time to play!!!!!
2GB vRAM doesn't look like it is enough on BF3 multiplayer maps...
http://forums.bit-tech.net/showpost.php?p=3041448&postcount=102
glad you got it sorted![]()
The guy has 2x680's so the ram shown is doubled. He is infact using 1250MB max
i thought that was amd cards that did that, on nv cards it shows correct, the poster has 4gb cards
Thanks,
I got the choice of two new ones or waiting for the 670 4gb version. I took the first and got two new Jetstreams , only time will tell if I made the right choice.
My results are getting better as 1 of the cards wasn't working fully,it's great playing BF3 3screens with nearly all maxed out at over 80fps. So what will be interesting is if the 670 4gigs preform similar, so now to clock them to see if things improve.
