3D monitor
20 Mar 2005
Leicester
Hey, Im looking at getting a 3D monitor but after a couple of days research I am non the wiser.
Im running an Nvidia KFA2 GTX680 which I believe restricts my options (rest of rig in sig if it matters). I use the Dual link DVI currently and would prefer to use that over display port
Can you recommend a good panel for 3D gaming with nvidia. Would prefer 27" but not totally against dropping to a 24" if it will give me a better range of options or quality.
Budget is around £500, could possible stretch an extra hundred or so for the right product if required.
Cheers
Macca
think I have narrowed it down to the Benq XL2420T 24"
any idea when the Nvidia 3d Vision 2 kits will be in stock? website just says overdue
That's your best choice go for it....i have a GTX680 too with the BenQ XL2420T it's like having Messi and Ronaldo in your football team.:p
By the way see if OcUK could still do the deal for you, worth contacting them to see.(they used to sell monitor+kit+arkham city for like £370 or so at one point)
I've been stuck between this and the samung, finally decide on the benq and the glasses are out of stock :(.... just to let you know I've sent a webnote and they have no ETA on the glasses and cant comment on if that bundle deal will be up again
