- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Hi guys
We have another exclusive. Xilence PSU's with amazing looks and under the hood perfection.
Xilence XQ Series 750W '80 Plus Gold' Power Supply @ £149.99 inc VAT
The totally new XQ power supply unit series is a complete new development. The new creeper is not a compact chump like normal but has a conical site where two 60mm fans are integrated. These is the visible part of the new Direct-Airflow-Technology that guarantees soundless work at maximum performance. Internally the cooling concept seperates the PSU in two cooling areas which are controlled by temperature sensors. If the temperature rises in one are the fan for these area starts to work slowly.
Because of the high efficieny the PSU works most of the time in soundless passive mode. The fans start to work at a last of 20-30% to support the cooling. The PSUs are a perfect solution for users that are sensitive to noise, but want to use the security of an active cooled power supply unit. A red status LED at the back of the PSU shows when the power supply unit is working – you won‘t recognize by the noise level. The modular cable management helps to organize a clean and structured inner life in the chassis.
- Semi Fanless
- 5 Year Warranty
- Advanced Modular Cable Management
- Dual Fan
- Power-on LED
- Active PFC
- OCP, OVP, SCP, OPP, OTP Protection
- Fanless operation up to 20% load
- Direct Air Flow Technology
- Special PCB hosing designed for optimal air flow and cooling
+3.3V @ 20A
+5V @ 20A
+12V1 @ 18A
+12V2 @ 18A
+12V3 @ 18A
+12V4 @ 18A
+12V5 @ 18A
-12V @ 0.5A
+5VSB @ 4A
- 1 x P8 Connector
- 1 x Dual P4 Connector
- 2 x PCI-E 6+2 Pin Connectors
- 1 x PCI-E 6 Pin Connector
- 1 x Tri Molex Connector
- 3 x Quad SATA Connectors
- 1 x Quad Molex Connector (and FDD Connector)
- 1 x 20+4 Pin Connector
Only £149.99 inc VAT.
ORDER NOW
Xilence XQ Series 850W '80 Plus Platinum' Power Supply @ £159.95 inc VAT
- Semi Fanless
- 5 Year Warranty
- Dual Fan
- Power-on LED
- Active PFC
+3.3V @ 20A
+5V @ 20A
+12V1 @ 16A
+12V2 @ 16A
+12V3 @ 16A
+12V4 @ 16A
+12V5 @ 16A
-12V @ 0.5A
+5VSB @ 4A
- 1 x P8 Connector
Only £159.95 inc VAT.
ORDER NOW
- Semi Fanless
- 5 Year Warranty
- Dual Fan
- Power-on LED
- Active PFC
+3.3V @ 20A
+5V @ 20A
+12V1 @ 18A
+12V2 @ 18A
+12V3 @ 18A
+12V4 @ 18A
+12V5 @ 18A
-12V @ 0.5A
+5VSB @ 4A
- 1 x P8 Connector
ORDER NOW
- Semi Fanless
- 5 Year Warranty
- Dual Fan
- Power-on LED
- Active PFC
+3.3V @ 20A
+5V @ 20A
+12V1 @ 16A
+12V2 @ 16A
+12V3 @ 16A
+12V4 @ 16A
+12V5 @ 16A
-12V @ 0.5A
+5VSB @ 4A
- 1 x P8 Connector
ORDER NOW
