Borked Windows on a laptop - system repair not working
6 Sep 2005
Hi everyone
I hope someone has an answer to this, it's a tricky one!
I'm trying to repair a family members laptop that has stopped booting, it says as it's trying to boot Windows:
"File: \windows\system32\config\system
Status: 0xc00000e9
Info: Windows failed to load because the system registry file is missing, or corrupt."
Ho ho I thought, no worries, I'll run the repair from the Windows disc...yeah that doesn't work...
Nor will it boot into safe mode...
Usually I'd got for wiping the drive but it has more then THREE YEARS of family photos, movies, home and work documents, school work....you name it.
Yes I told them to back it up often, I even got them some external HDDs for the process...and it didn't happen.
So this data *has* to be recovered. The install isn't as important, I can put Windows 7 on it, but the main thing is I can't lose the data.
Any suggestions?
Thanks!
I would use a linux live CD such as Ubuntu or Knoppix to boot from and backup what you need, then do a clean install.
Or pull the drive and plug it into a pc. the sata connectors are the same on laptops and pcs.
Thanks for the replies guys.
I'm not sure about the linux route, I've never done that before...don't really want to experiment with something so important.
I did consider taking the drive out but I wondered if I would be able to access the files or not.
As far as I'm aware (I'll have to ask and check) there are up to four user accounts on there, probably all password protected...if I'm accessing the folders from another machine will I be able to open the password protected folders?
I had a feeling I tried it with one of my drives some time ago and it wouldn't let me into them...?
Try disabling as many hardware items as you can in the BIOS, USB/firewire etc. Also, just try booting with one stick of RAM, alternate the stick/slot if it crashes.
Are you able to use system restore on the recovery disk?
Before doing anything too drastic I'd make sure to have a backup as well, just in case. Use something like acronis.
If you do go down the route of plugging it into another machine you will be able to access the files provided they're not encrypted (I'm fairly certain they won't). It'll pop up with a message looking for you to grant administrative rights when you try to access them.
The only time you will have issues accessing the user data is if they have told the machine to encrypt their files, which is not a default action.
Being a notebook there is a high chance that you have hard errors on the disk. Download an ISO of seatools and run that on the drive first so you can work out what you are dealing with.
Ok
In a working PC, download Ubuntu and burn it to a CD using IMGBurn
Pop this CD into the drive of the laptop and boot from it (like you would a Windows disc)
You get the option of what you want to do, 'try ubuntu' or 'install ubuntu' pick try.
Now it will boot into a 'live' ubuntu session which has a fully working desktop, it won't write anything to the hard drive. From here you can plug in an external drive and copy the files off.
Just try it, it's much easier and less daunting that it sounds.
Really is that simple :)
Here's a video of it loading up, nothing to it!
Ah brilliant, thanks for those tips guys, I'll give them a go, starting with the Ubuntu idea as that is the least intrusive, thanks everyone!
If I do manage to get the data off using Ubuntu, is there an option with it to check the disk in case it is a mechanical error?
I just wanted to say thanks and pass on my thanks from the family member.
The Ubuntu idea was absolutely spot on and worked a treat!
I managed to recover all the lost data and I think it was quite lucky, I rang an HD Tune scan on the drive and it discovered some damaged areas that were red on the scan...then it crashed the program!
Very lucky to recover everything I think!
Thanks again everyone! :D
