Any Javascript/PHP experts?
24 Sep 2005
Middlesbrough
Hello chaps.
I've copied one website to another server and the index page loads up but when you click any of the links it just says the page cannot be found. For example site.com/about.html which is the link on the site but about.html doesn't exist anywhere!
The whole site seems to run from a javascript and I believe there will be some line of code somewhere which I need to change as the directories are different on the servers (httpdocs and public_html)
Is this an easy fix?
Can we see?
This is index.php
Code:
<?php
* @version		$Id: index.php 11407 2009-01-09 17:23:42Z willebil $
* @package		Joomla
* @copyright	Copyright (C) 2005 - 2009 Open Source Matters. All rights reserved.
* @license		GNU/GPL, see LICENSE.php
* Joomla! is free software. This version may have been modified pursuant
* to the GNU General Public License, and as distributed it includes or
* is derivative of works licensed under the GNU General Public License or
* other free or open source software licenses.
* See COPYRIGHT.php for copyright notices and details.
// Set flag that this is a parent file
define( '_JEXEC', 1 );
define('JPATH_BASE', dirname(__FILE__) );
define( 'DS', DIRECTORY_SEPARATOR );
require_once ( JPATH_BASE .DS.'includes'.DS.'defines.php' );
require_once ( JPATH_BASE .DS.'includes'.DS.'framework.php' );
JDEBUG ? $_PROFILER->mark( 'afterLoad' ) : null;
 * CREATE THE APPLICATION
 * NOTE :
$mainframe =& JFactory::getApplication('site');
 * INITIALISE THE APPLICATION
 * NOTE :
// set the language
$mainframe->initialise();
JPluginHelper::importPlugin('system');
// trigger the onAfterInitialise events
JDEBUG ? $_PROFILER->mark('afterInitialise') : null;
$mainframe->triggerEvent('onAfterInitialise');
 * ROUTE THE APPLICATION
 * NOTE :
$mainframe->route();
// authorization
$Itemid = JRequest::getInt( 'Itemid');
$mainframe->authorize($Itemid);
// trigger the onAfterRoute events
JDEBUG ? $_PROFILER->mark('afterRoute') : null;
$mainframe->triggerEvent('onAfterRoute');
 * DISPATCH THE APPLICATION
 * NOTE :
$option = JRequest::getCmd('option');
$mainframe->dispatch($option);
// trigger the onAfterDispatch events
JDEBUG ? $_PROFILER->mark('afterDispatch') : null;
$mainframe->triggerEvent('onAfterDispatch');
 * RENDER  THE APPLICATION
 * NOTE :
$mainframe->render();
// trigger the onAfterRender events
JDEBUG ? $_PROFILER->mark('afterRender') : null;
$mainframe->triggerEvent('onAfterRender');
 * RETURN THE RESPONSE
echo JResponse::toString($mainframe->getCfg('gzip'));
The site is http://www.gmburton.com
My brother has the original site and wants to amend this site into a personal portfolio and all he asked me to do was copy one to the other but it's more difficult than I thought.
That's PHP, not javascript. You may want to contact to a mod to change the thread title.
My guess would be there's something awry in the URL rewriting. Check you've copuied the .htaccess file properly.
htaccess doesn't exist (or I can't find it) on server 1 but it does on server 2.
Code:
# @version $Id: htaccess.txt 13415 2009-11-03 15:53:25Z ian $
# @package Joomla
# @copyright Copyright (C) 2005 - 2008 Open Source Matters. All rights reserved.
# @license http://www.gnu.org/copyleft/gpl.html GNU/GPL
# Joomla! is Free Software
#  READ THIS COMPLETELY IF YOU CHOOSE TO USE THIS FILE
# The line just below this section: 'Options +FollowSymLinks' may cause problems
# with some server configurations.  It is required for use of mod_rewrite, but may already
# be set by your server administrator in a way that dissallows changing it in
# your .htaccess file.  If using it causes your server to error out, comment it out (add # to
# beginning of line), reload your site in your browser and test your sef url's.  If they work,
# it has been set by your server administrator and you do not need it set here.
##  Can be commented out if causes errors, see notes above.
#  mod_rewrite in use
RewriteEngine On
########## Begin - Rewrite rules to block out some common exploits
## If you experience problems on your site block out the operations listed below
## This attempts to block the most common type of exploit `attempts` to Joomla!
## Deny access to extension xml files (uncomment out to activate)
#<Files ~ "\.xml$">
#Order allow,deny
#Deny from all
#Satisfy all
#</Files>
## End of deny access to extension xml files
RewriteCond %{QUERY_STRING} mosConfig_[a-zA-Z_]{1,21}(=|\%3D) [OR]
# Block out any script trying to base64_encode **** to send via URL
RewriteCond %{QUERY_STRING} base64_encode.*\(.*\) [OR]
# Block out any script that includes a <script> tag in URL
RewriteCond %{QUERY_STRING} (\<|%3C).*script.*(\>|%3E) [NC,OR]
# Block out any script trying to set a PHP GLOBALS variable via URL
RewriteCond %{QUERY_STRING} GLOBALS(=|\[|\%[0-9A-Z]{0,2}) [OR]
# Block out any script trying to modify a _REQUEST variable via URL
RewriteCond %{QUERY_STRING} _REQUEST(=|\[|\%[0-9A-Z]{0,2})
# Send all blocked request to homepage with 403 Forbidden error!
RewriteRule ^(.*)$ index.php [F,L]
########## End - Rewrite rules to block out some common exploits
#  Uncomment following line if your webserver's URL
#  is not directly related to physical file paths.
#  Update Your Joomla! Directory (just / for root)
# RewriteBase /
########## Begin - Joomla! core SEF Section
RewriteCond %{REQUEST_FILENAME} !-f
RewriteCond %{REQUEST_FILENAME} !-d
RewriteCond %{REQUEST_URI} !^/index.php
RewriteCond %{REQUEST_URI} (/|\.php|\.html|\.htm|\.feed|\.pdf|\.raw|/[^.]*)$  [NC]
RewriteRule (.*) index.php
RewriteRule .* - [E=HTTP_AUTHORIZATION:%{HTTP:Authorization},L]
########## End - Joomla! core SEF Section
Could that be the issue?
Code:
# @package Joomla
RewriteEngine On
#<Files ~ "\.xml$">
#Order allow,deny
#Deny from all
#Satisfy all
#</Files>
# RewriteBase /
Yes.
A hash "#" in a htaccess file acts as a comment, it nullifies the line. So they've got # RewriteBase / and their instruction says to remove that if you're not linking to physical file paths, which I'm assuming Joomla doesn't.
Download the htaccess file or modify it direct on the server if you wish, delete that hash, save the htaccess file. Hard refresh one of your pages.
That would explain why the index works because that is a physical file.
can we see the copied site? are the links "correct"... try going to those links yourself i.e. by typing into browser and see what happens?
COuld be that you copied but you had to change some of the link creation to take into account the new "site" as it were..
