**NVIDIA GT 610, 620 & 630 NOW AVAILABLE FROM OcUK!!**
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Here is the entry level 6xx series from NVIDIA:-
KFA2 GeForce™ GT630 1024MB GDDR3 128bit DVI/HDMI/VGA/PCI-E Graphics Card @ £53.99 inc VAT
Every PC deserves great graphics. NVIDIA GeForce GT 600-series graphics cards deliver premium multimedia performance-every time. Trust NVIDIA GeForce GT 630, 620, and 610 dedicated graphics for a faster, more immersive experience in your favorite applications.
- CUDA Cores: 96
- Core Clock (MHz): 810
- Boost Core Clock (MHz): n/a
- Processor Clock (MHz): 1620
- Memory Amount: 1GB DDR3
- Memory Interface: 128-bit
- Memory Clock (MHz): 800 (1600 effective)
- Memory Bandwidth(GB/sec): 25.6
- Texture Fill Rate (billion/sec): 13 / 13
- Direct X 11
- Outputs: Dual DVI-I / HDMI / VGA
- Power Connectors: None
- TDP: 65W
- 2yr Warranty
Only £53.99 inc VAT.
ORDER NOW
KFA2 GeForce™ GT620 2048MB GDDR3 64bit DVI/VGA/PCI-E Graphics Card @ £53.99 inc VAT
- CUDA Cores: 96
- Core Clock (MHz): 700
- Processor Clock (MHz): 1400
- Memory Amount: 2GB DDR3
- Memory Interface: 64-bit
- Memory Clock (MHz): 333 (667 effective)
- Memory Bandwidth(GB/sec): 5.3
- Texture Fill Rate (billion/sec): 13 / 11.2
- Direct X 11
- Outputs: Dual DVI-I / VGA
- TDP: 49W
- 2yr Warranty
ORDER NOW
KFA2 GeForce™ GT620 1024MB GDDR3 64bit SILENT DVI/HDMI/VGA/PCI-E Graphics Card @ £44.99 inc VAT
- CUDA Cores: 96
- Direct X 11
- TDP: 49W
- 2yr Warranty
Only £44.99 inc VAT.
ORDER NOW
KFA2 GeForce™ GT620 1024MB GDDR3 64bit Low Profile DVI/HDMI/VGA/PCI-E Graphics Card @ £44.99 inc VAT
- CUDA Cores: 96
- Direct X 11
- TDP: 49W
- 2yr Warranty
ORDER NOW
KFA2 GeForce™ GT610 2048MB GDDR3 64bit Low Profile SILENT DVI/HDMI/VGA/PCI-E Graphics Card @ £41.99 inc VAT
- CUDA Cores: 48
- Memory Clock (MHz): 500 (1000 effective)
- Memory Bandwidth(GB/sec): 8
- Texture Fill Rate (billion/sec): 13 / 6.5
- Direct X 11
- TDP: 29W
- 2yr Warranty
Only £41.99 inc VAT.
ORDER NOW
KFA2 GeForce™ GT610 2048MB GDDR3 64bit Low Profile DVI/HDMI/VGA/PCI-E Graphics Card @ £41.99 inc VAT
- CUDA Cores: 48
- Texture Fill Rate (billion/sec):13 / 6.5
- Direct X 11
- Outputs: Dual DVI-I / HDMI /VGA
- TDP: 29W
- 2yr Warranty
ORDER NOW
KFA2 GeForce™ GT610 1024MB GDDR3 64bit Low Profile SILENT DVI/HDMI/VGA/PCI-E Graphics Card @ £37.99 inc VAT
- CUDA Cores: 48
- Direct X 11
- TDP: 29W
- 2yr Warranty
Only £37.99 inc VAT.
ORDER NOW
KFA2 GeForce™ GT610 1024MB GDDR3 64bit Low Profile DVI/HDMI/VGA/PCI-E Graphics Card @ £37.99 inc VAT
- CUDA Cores: 48
- Direct X 11
- TDP: 29W
- 2yr Warranty
ORDER NOW
96 shader card any good for a dedicated physx card?
I run a GT 430 which has 96 cores and 128bit memory bus as a dedicated Physx card, they are perfect for it. only the ones with the wide memory bus and 96 cores thought don't think a 64bit would cut it.
Can these cards be used to power a triple head display, kind of like eyefinity ?
Or do they not have the ability to use all three ?
I've always wondered what the point of these entry level cards were. The cost never seems to justify the performance over integrated graphics.
shameless bump ? Interested in just a basic "work" pc, but with triple head, hopefully without the higher costs of more expensive ati cards that need displayport monitors/adapters.
