One 7950 died, so.........
Yeah, not bad. Had mine at 1125 core at 1.18V
Don't even think I will be bothering to OC my 670's though, as in the games I play, they are already faster than 7970.
Must say, it's been so long, am quite excited to try Nvidia again :D
Is the 7950 a good clocker?
It's a great clocker, as is the 670.
I really see no need at all why we need to turn every thread asking an honest question like this into a flame war, i really don't.
Can we not all just live on benchmarks from reputable sources pertinent to each OP's needs as a means of recommending what we choose to do?
Also, no need to bring every minor issue that some users are facing and tarnishing every GPU of a manufacturer with the same brush, it's pathetically childish.
Yes, some users will face problems, but Dave, you may aswell say "don't get and xbox, they suffer the red ring of death." It's a poor fanboy argument!
For future reference incase anyone else views this thread, don't worry about 2GB VRAM. You will run into GPU limitations long before VRAM causes an issue. 2GB is enough for 5760x1080 in around 99% of cases.
Oh.... I completely forgot that Nvidia disabled PCI-E 3 support on X79 boards....
ARGH!!!!!
Are they likely to enable it again?
PS - I know it doesn't have a huge impact, but it's a psychological thing. I didn't get near top of the line stuff to run less than it should.
ARGH!!!!!
Nvidia had to disable pcie 3 support in the drivers.
They had no other option.
Some MB's just don't work properly when running gen3.
I only have 2 x79 boaeds so not a big sample but i can tell you that the ASUS X79 pro works fine with pcie3 enabled and the ASrock extreme 4 i have does not.
It just black screens freezes and really misbehaves when i force pcie3 on in the driver.
Now this means the drivers that came with my 680's in the box which do not have the pcie3 restriction are useless with the ASrock.
It must have been quite a headache for NV as the shipped drivers didn't work with a lot of boards.
Looking at the bios revision history on the ASUS there was a pcie3 compatability fix mentioned.
It works fine and i use it running at pcie3x116 with the 680's
Maybe an updated bios can fix this issue but i dont have enough info.
seems nobody is talking about it.
So another person ignores the rhetoric from dave_beast about how good AMD are and goes to nVidia. If you put your point across in a manner that didn't smack of brand loyalty to the death you might sound more credible ;)
I'm stuck between:
1) Single GTX 680 4GB for £500
2) SLI GTX 670 2GB
3) Tri-fire 7850 2GB
4) Just get another 7950
To be honest, I was surprised how well the single 7950 handled BF3.
Exclude Option #2. There is only one crossfire connector on the 7800's for tri-fire is not possibe.
Glad I didn't go with that option then! Would have been severely hacked off if they arrived and could only use two :D
I went with sli 670 - but am worried now about the reports of them whining :(
You can lead a horse to water and all that, but hey, if you get on with the 6** cards all well and good, but it's wise to be aware of the problems before diving in.
If the 6** cards we're considerably more powerful than the 79** i'd of gone down that road, but they're not, and going by the Nvidia forum they've got big issues as well.
You lot (who would buy an Nvidia branded potato) can spout however much you like about fanboism, just because i'm outspoken and choose not to be intimidated by your whining, I honestly don't care, i'm simply here to point out facts.
Oh well, by the end of the day/week I should have a good idea of the pro's and con's of both/either, having come from crossfire 7950 to these.
Perhaps the issues I had with AMD will turn out to be minor in comparison to Nvidia's issues, or maybe will find myself wishing had never touched AMD :)
Would be nice to just stick them in and be over the moon, but as overpriced as they are, you can bet I am going to be picky, and not settle simply cause returning will be hassle.
Surely the best option would be to use the warranty to replace the dodgy 7950 free of charge :/
Buying two new cards because you got unlucky with one seems a bit extreme to me!
All, I can say is "EWWWW!!!"
First, can't even get +55 core, which gave a boost up to around 1200.
Though, while I could live with that, temps were hitting on 90C and yes, they do make a horrible whining noise!
Ick! Feels so cheap and nasty.
Guess will be sticking with my single 7950 for now
Because I wanted to use the opportunity to go for cards that exhaust heat out of the case....
It was between reference 7970 and the 670's. I made the wrong choice and now the ref 7970's are gone at the price I was considering them :(
It does come with a pre oc - think it's 965 rather than 915, plus boost or whatever. Yeah, was on auto fan
Doesn't matter in the end, the noise is horrible.
2 reference HIS 7970 ordered...
The change won't cost me all that much by the time I get refund and sell my remaining card + games that will get with cards.
Hope it's 3 games per card though :)
Hope I am done now... spent a fortune recently, and just want to start playing some games again...
