Looking to Buy a New Graphics Card ATI 6850 but which one?
3 Jun 2010
Hi,
I am looking to buy a new graphics card, I only have a Corsair 450W Power Supply which i've been told is ample for a single 6850, If I need another 6850 then I can just upgrade it,
Anyway, I was looking at getting this: http://xfxforce.com/en-gb/Products/Graphics-Cards/AMD/AMD-Radeon-HD-6000/AMD-Radeon-HD-6850.aspx
But I can see a few others on the OCUK website that look very similar or maybe slightly better? I don't know,
I can get the XFX XXX for just a tad over £100 so im really looking around this price point and probably no more,
Any suggestions would be great
Thanks guys!
Stay away from Sapphire as the RMA process is disgusting. If you have problems, you will be lucky to see the card or a replacement again.
They're both vastly overpriced in relation to the MSI.
The performance will be the same, out of those two I'd get the sapphire, but I'd always get the MSI first.
Why would you go through Sapphire? Always go through your E-tailer. Even after the first year, the E-tailer can act as middle man.
The drivers are the same drivers that the other 6850's run, you'll be using them from AMD's site.
Software? Unaware what you mean ; Unless you mean overclocking like MSI Afterburner?
The e-tailer will still have to send it to sapphire. Look through the 'lets see how good warrantys really are' thread to see my point on Sapphire.
Anyone know of any decent After market coolers for the 6850? I have the XFX one and its noisy as hell, even with the fan speed turned down to about 40%,
I've heard the arctic range are good? probably be a good replacement for the stock MSI one aswell?
