Forcing Vsync in CCC
12 Dec 2005
Trying to fix some stuttering issues in Diablo 3 and I can't seem to get Vsync + Triple buffering to force in CCC.
I set Vsync to always on and check the box for triple buffering in CCC however it has no affect when in game. I know this because the FPS rises way above 60.
I am running a GPU overclock in afterburner, not sure if that has anything to do with it?
Any help appreciated.
Cheers
You can not Force Vsync + Triple buffering with CCC In Vista or Windows 7 in D3D games, it work for OpenGL only.
Thanks for that mate. When I run it, nothing happens though. I tried running it as Admin and still nothing happened. Just doesn't seem to load.
Look in your Taskbar notifications and set it to show the icon, then click the icon to bring up the configuration window then you can turn TB and Vsync on.
Look in your Taskbar notifications and set it to show the icon, then click the icon to bring up the configuration window then you cant turn TB and Vsync on.
It doesn't show up in the notifications either mate.
EDIT - Now it does. Cheers. Will have a mess.
