Ok so its my first time overclocking and want to check if everythings ok so can you guys check these values on occt, are the voltages correct?
i have a z77a-gd65 motherboard and to overclock the only thing i adjusted on the oc genie 2 menu was instead of a defualt overclocked i changed it to customised and changed the cpu ratio to 44 so 44 x 100mhz, 4.4ghz
everything else is on auto and oc genie adjusts everything else. i also turned of intel turbo boost.
Image uploaded with imageshack
