How do you clean your cast iron skillets?
1 Jan 2010
Cirencester, nr Swindon
Just interested really, When I got mine I properly seasoned it etc and its great now, no sticking/burning. Eggs cook brilliantly on it.
Everyone I speak to thinks I'm mad in that I never ever wash it. I wipe it out whilst still warm and when it's clean I put a drop of olive oil in, rub round and just leave it at that. Perfect for the next use.
What do you all do?
12 Jan 2006
Edinburgh
Allow pan to cool slightly, but while still warm
Rinse and wipe in warm water
Dry thoroughly
Re-oil with a paper towel
Store with a paper towel on top
Man of Honour
9 Jan 2010
mine goes into hot soapy water and gets a proper clean, i know its not a great thing to do with it but it doesnt get used much at all, maybe once every 2-3 months
Man of Honour
Man of Honour
3 May 2004
Kapitalist Republik of Surrey
Scour it in hot soapy water. Apart from the griddle pan, I find cast iron skillets pretty disgusting when people just wipe them out. Nightmares from my friend's mum's one when we were teenagers and you'd get all sorts of black residue end up in your fry up and it would taste of whatever was cooked in it before because she just used to wipe it out and oiled it. Gross :(
2 Jul 2009
Bridge of Weir, UK
Wipe with paper towel then wipe with a sponge and hot water.
If its really dirty I heat it up till its just started smoking then pour boiling water in to it, this will lift any residue but will also effect the seasoning a little it will still be non-stick though.
And I'm not taking the comments about using soap seriously :)
20 Apr 2011
My Mum taught me to use newspaper. That might have worked in ye olden times when newspapers were printed differently, but nowadays I use paper towels like others have said.
Caporegime
17 Oct 2006
I tend to keep my heated and add warm water from the kettle, boil it for a short while then rinse and wash with soapy water. This way you get most of the gunk off :)
24 Oct 2005
North East
Are CI pans really that good to have if there so troublesome to clean and prevent rust and all that. Sure they can go really hot but is that it, is it really needed apart from searing steaks?
2 Jul 2009
Bridge of Weir, UK
They are no problem if you season and clean without using soap or scrubbing in fact you will have a non-stick pan that you can cut bacon in the pan without worrying about damaging the surface make great stir fries, cook eggs and on top of that make great steaks.
