May I ask why you want to flash it?
Sure
Want to increase clock speeds etc
ah, in that case I would say MSI AB really is the best option. I'm not sure MSI will cover RMA's for bricked cards unless you were instructed to do so. Flashing isn't something that's done for the sake of it
Any reason you don't like AB?
Well its not that i dislike it, its just that i prefer to not have any apps running in the backround that could be accidently changed if you see what i mean.
ah, I'd say MSI afterburner is a very reliable piece of software.
It's certainly better than having to flash a BIOS!
As long as you don't do stupid things with the voltage/OCing, MSI AB won't damage your card.
Also, if you change things in the BIOS, then MSI will know you've OC'd
You don't flash the card. You just move some sliders in MSI Afterburner. If you don't like it then get a different overclocking piece of software.
There's absolutely no reason to 'flash' it.
Why on earth do you not like having applications in the background?
Blunt way of putting it, but I have to agree.
Sorry OP, but I really don't think we should be helping you do something stupid with your card![]()
I was only being blunt because you were already polite and he ignored you hehe![]()
I appreciate the concerns guys and i appreciate the help and advice you have given me this far.
Thing is im not the only person who uses this machine and i dont want to have an overclocking app running on this machine just incase it accidently gets used and end up wrecking my card.
ive allready flashed the card once with an updated bios which had the voltage higher which has stopped my purple screen issues but im wanting to increase clock speeds etc but i cant find such a bios for my card.
Again i know the concerns and risk factor etc but its what im wanting to do.
down want overclocking software on my machine incase it accidently gets used and wrecks my card.
ok guys i go with the majority here and use msi afterburner
thank you for all the help
cheers
