- 21 Jun 2004
Hi, i recently purchased Diablo 3 and portal 2, both of which just about run on minimum detail, but get graphics errors after about 15 minutes causing the PC to crash. My current PC is:
Asus P5W DH delux
Core 2 duo @ 2.9ghz
2gb ram
ATi X1900 (latest drivers)
My feeling is that the graphics card is holding the system back and if i swapped to
http://www.overclockers.co.uk/showproduct.php?prodid=GX-154-MS&groupid=701&catid=56&subcat=411 , i would be able to play the games.
Few questions though, would the above card work in a PCIe 16x 2.0 slot? I do have a 2nd 6 slot power connector for the card, so that shouldnt be a problem.
Is it worth getting another 2gb of ram?
Thanks for any advice
*edit* With DDR 2 can i mix different manufacturers as long as the speeds are the same? Also, do modules have to be the same size? IE 4x 1gb, or would 2x1gb and 2x2gb for 6gb work?
Asus P5W DH delux
Core 2 duo @ 2.9ghz
2gb ram
