£100 GFX
18 Oct 2002
Birmingham
I'm looking to give my PC a refresh for Diablo 3 and other games. I have just bought a Q6600 (@3.6ghz) with 8Gb RAM from the MM.
My 512Mb X1900 doesn't cut it these days at 1080p so I'm looking at spending £100 on a new card. Any suggestions?
Second hand would be ideal, but don't mind buying new if there's something really worthwhile.
Thanks!
Found a second hand 6950 2Gb. Slightly over budget, but worthwhile I think. Should be able to do some tinkering with the clocks too!
Bargain
I run Diablo III on my HD 7950 between 120-160FPS so I would imagine the 6850 will give you well over 60FPS. You cannot go wrong for £83 and you can always X-Fire it later when you need it.
