Hi folks,
I'm about to buy the spec above and have the usual questions - am I making any errors with the components? Or could I knock any money off without losing performance?
I may have gone a bit tight with the RAM, I haven't upgraded in years and 8GB seems like an astronomical amount to me, but most manufacturers only seem to list 16 and 32 in the quad channel kits. This makes me wonder if 8GB is enough for a machine like this. I have also gone for the 1600MHz RAM, is that OK for a Z77 Ivybridge setup?
Mostly just looking for peace of mind before I hit the 'bankrupt me now' button.
Many thanks as always.
Edit: Forgot to ask, will that heatsink fit inside this case? The case is listed as 207mm wide, the heatsink as 151mm high, 56mm for the case gap + motherboard mounting + cpu heatspreadder, sound ok? I don't seem to have much intuition on this one.
