strange issue - is this normal?
28 Dec 2009
Wales
I have a Asus VE247H 24" Widescreen LED Multimedia Monitor. Since upgrading to a Gtx 670 connected via DVI I have noticed that there is a small bacl border, only a couple of pixels wide between the displayed screen and the bezel.
Is this normal?
I thought it might be something to do with over/under scan but that has not changed anything. I can't say if it was or wasnt there before and my google foo appears to be very weak regarding this.
Cheers for any help.
Cheers for the reply I will have a read of that now. It may well have been there before, but having only just noticed it I thought I would check if it is normal. JNot long had my Gtx 670 so just checking everythings ok.
It's normal then?
