Im deffo going to upgrade my CPU cooler, and this appears to be at a great price.
My main requirement is quietness, but this extreme cooler, supports 2 x 120mm fans.
Where do these fit on, as it looks exactly the same size as a normal cooler (It doesn't look like the H100).
Does dual fan mean a push-pull configuration? Whats the best set-up in terms of an OC to approx 4-4.5GHZ on a i5 2700k and near-silent operation
It doesn't have to be the max OC, I just want a good OC with the best noise levels. (I prefer silent cooling). I've looked at the apache black fans, and I'll be definately purchasing one of them. Wouldn't two fans be loud?
What if i put one apache black, and one low RPM fan, like a noctua for example. How would I set it up like this to provide good airflow, but also lowest noise levels?
Or would it be better if i got a phanteks?
Replies much appreciated
