PSU help pls. (pics inside)
3 Nov 2011
East Anglia
PSU help pls. (pics inside) CiT S010BA Black Slim Micro ATX Tower (case)
I just had a CIT S010BA delivered. It came with a psu of some sort and just want to know if this is capable of powering the following:
ASUS P8H61 M Pro
Intel G840 cpu
GT 520
1Tb HDD 7200rpm
1 Bluray player
Also don't know if the PSU is a micro atx, can't find any info on the web.
Your advice is greatly appreciated. Ta
click to enlarge
Its name is CIT M-300U, its 300W mATX PSU.
AC INPUT: 230VAC 3A 50-60Hz Model M-300U
DC
Output
Max +3.3V +5V +12V -5V -12V +5VSB
7A 8A 9A 0.8A 0.5A 2A
300W
Features
Silent PSU with Temperature Control Fan
Complies with Intel ATX12V 2.31VER
Fan Speed Control Function Inside
Passive PFC (Power Factor Correction)
Low noise with intelligent-thermal fan control technology
ATX 12V Compliant for all kinds of CPU and mainboard
MTBF 50,000 Hours @ 25 degrees C
Connections
20+4 Pin Main Connectors:
1
P4 4-Pin 12V Connectors:
1
4-Pin Molex Peripheral Connectors:
4
SATA Connectors:
2
Floppy Drive Connectors:
1
Unsure about being able to power that system. CIT aren't a make i know anything about.
Based on the PSU spec it should have a maxium output of 180 W +12 V.
Your system should be well under that, closer to 100 W on full load.
It's a cheap PSU, so a slightly high risk of damage to the PC if it fails, but on low power system the risk is a lot lower compared to a gaming PC with a decent graphics card.
I've dealt with a lot of failed cheapo PSUs on similar low powered systems and none were damaged by the PSU. That doesn't mean it can't happen though. :P
Now up and running. Psu is rather noisy. Will suffice for now until I find a replacement. Anyone knows which and where to get a good one?
edit: I forgot to install the GT520 !
You got any pics of the case with the panel on monkey? and the front?,
Also did you keep the speakers it has built in or did you take them out?
I just replaced the psu this morning with a Silverstone 450w because the Cit psu is annoyingly noisy, but I forgot to take a few pics. I will take some and post them later.
The speakers are ok if the volume is set up to 50%, if I adjust the volume adjuster higher, I hear some humming. I haven't removed them yet. There is no writing on the speakers anywhere so don't know the details.
It says Pentium P4 on it, how old is that unit??
The psu was manufactured 08/2011 IIRC.
Thanks PC monkey, looks slick :cool:
Will definitely put it on order in a week or so, and then the PSU, where did you get yours from? direct from Silverstone?
pc monkey, was that a TFX or SFX PSU, have something similar in an old PC that I was looking to update whilst keeping the lovely case hence my ask!
BTW, it looks nice!
*no disguised competitors, bending the rules won't go unnoticed*
does this support full height gpus??
no,low profile only
That looks really nice mate! welldone :D
thanks
BTW, it looks nice!
it's SFX (mATX)
