**ETEKNIX REVIEW THE OcUK EXCLUSIVE SAMSUNG GREEN MEMORY!!**
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
We sent Eteknix a kit of the Samsung Green 1600MHz from our stock, this was un-opened and un-tested, so no cherry picking going on. The guys have done a full review of the memory and lets just say they are very impressed, read the review here:-
Eteknix Review of Samsung GREEN Memory
Won their editors choice award:-
Samsung Green (MV-3V4G3D/US) 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz 30nm Dual Channel Kit @ £53.99 inc VAT
nonl2br
These Samsung Green kits are a world first using 30nm technology. This results in lower power usage, extended life and ultra low profile making them compatible with all DDR3 solutions including small form factor.<br/><br/>
Boost performance with Samsung genuine PC memory. As the number one memory supplier in the world, Samsung DRAM modules are made with 100% Samsung components. With the 30nm-Class DDR3 1600MHz Extreme Low Voltage UDIMM module from Samsung, you can get faster speed and greater reliability from your computer while consuming less energy. Use Samsung UDIMM DDR3 memory to replace or increase the memory in your desktop or server. This Samsung DDR3 memory module employs 30-nanometer technology and, as a result, uses up to 65 percent less power and is only two-thirds the size of conventional 60-nanometer memory modules. This version of Samsung DDR3 has a 8 GB capacity (2 DRAM modules, each with 4 GB). <br/><br/>
The other major advantage of these modules is their overclocking ability, in our own testing we achieved 2400MHz with CAS 11-11-11-28-1T timings with just 1.55v resulting in staggering levels of performance.
<br/><br/>
<strong>Features:-</strong><br/><br/>
- Model Name: MV-3V4G3D/US<br/>
- Main Board: INTEL/AMD<br/>
- System: DESKTOP/SFF<br/>
- System Type: DDR3<br/>
- M/B Chipset: INTEL P67, Z68, Z77, X79 & AMD Chipsets<br/>
- CAS Latency: 11-11-11-28 1N<br/>
- Capacity: 8GB (4GBx2)<br/>
- Speed: DDR3-1600 (PC3-12800)<br/>
- Test Voltage: 1.25-1.55V<br/>
- Registered/Unbuffered: Unbuffered<br/>
- Error Checking: Non-ECC<br/>
- Type: 240-pin DIMM Low Profile<br/>
- Warranty: Lifetime<br/>
<br/><br/>
<strong>
Overclocking Features (Not Guaranteed)</strong><br/><br/>
- 1600MHz (7-8-8-24 1N) @ 1.40v<br/>
- 1866MHz (9-9-9-27 1N) @ 1.40v<br/>
- 2000MHz (9-10-10-28 1N) @ 1.45v<br/>
- 2133MHz (10-10-10-28 1N) @ 1.45v<br/>
- 2400MHz (11-11-11-28 2N) @ 1.50v<br/>
- In our own in house testing we were able to achieve all the above clock speeds on an Asus X79 platform with 4x4GB modules (16GB total) SuperPI Stable too, 32M<br/>
Only £53.99 inc VAT.
ORDER NOW
For the money this memory is simply unbeatable and certainly works and clocks the best in Z77 and X79 platforms, truly incredible memory for the money and exclusively available from only OcUK in Europe and of course our partners Caseking. :)
A very nice review from eTeknix there. Proves your findings from initial overclocking of the product when it landed and I cant agree more with the conclusion. Not really anything better for the money :)
My 16gb of this turns up in 1 hour 28 minutes (according to the tracking link) will be testing this on an Asus X79 Rampage Formula IV :)
Looks like the reviewed set are the same batch as mine (1209), but I struggled to get mine stable at 2133MHz/1.625V. Probably as I have 4x4GB installed, and a "lesser" Z68 mobo (the UD3H only has two memory VRMs, one per channel). And I've never overclocked memory before.
Nevertheless, I've got 16GB running at 1866MHz/9-9-9-24 @ 1.325V, which is a great compromise for Sandybridge (and still higher speed, tighter latencies and lower voltage than spec) so I'm not complaining. They're still cheaper than any 1866MHz kits, and can hit 2400MHz+ with the right mobo and expertise. Low voltage/power is a bonus, and ultra-low profile means no problems with heatsinks/fans. Plus they look superb on a black/grey Gigabyte mobo.
Out of interest : Sandybridge is well known for showing minimal benefit of faster memory past 1600MHz or 1866Mhz. How do SB-E and IB compare?
"We haven’t taken a look at any memory in a while"
Always love a review that starts off admitting they have no other reviews of their own to compare to.
5UB, those sticks look stunning in there with performance to match IMO!
They look good, and they perform well.
Great for systems with beasty coolers, also great for small form factor systems too as they take up pretty much no room! :)
I want some of this because it's small. I won't be overclocking it so the fact it's a good clocker is more of a nuisance for me as it puts the price up!
Remember guys we use these awesome memory kits in our Intel Core i5 3570K Z77 Overclocked bundles.
http://www.overclockers.co.uk/productlist.php?groupid=43&catid=2053&subid=2288
"Krypton Z77 660i" Intel Core i5 3570K 3.40GHz @ 4.40GHz DDR3 Ivybridge Overclocked Bundle @ £417.97 inc VAT
Designed by experts the "Krypton Z77 660i Bundle" is a pre-configured high performance "plug and play" bundle featuring optimised settings. The Guaranteed 4.40GHz overclock has the processing power and speed unseen at this price point ever before. The "Krypton Z77 660i" will accelerate your computer experience into the next level.
Why You Should Buy This Bundle?
- A solid, optimised 4.40GHz overclock profile provides outstanding processing performance
- Prebuilt, overclocked and configured. Just "plug and play"
- 8 Hours stressed tested and quality controlled
- Quad Core overclocked CPU
- 8GB of Dual Channel DDR3 memory delivers unsurpassed bandwidth
- USB3, SATA 6GB/s and Intel Ethernet for next gen computing
Bundle Specification
- CPU: Intel Core i5 3570K 3.40GHz @ 4.40GHz Ivybridge CPU
- Motherboard: Gigabyte Z77-D3H Intel Z77 (Socket 1155) DDR3 Motherboard
- RAM: Samsung Green 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz Dual Channel
- Cooler: Prolimatech Super Mega CPU Cooler w/ Sharkoon Silent Eagle 2000RPM 120mm Fan
- Artic Silver 5 Thermal Compound
Service Package
- Full 12 Month collect and return warranty
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
Note - Please note that adding in additional memory to the spare slots will require new BIOS settings and the maximum clock speed attainable may be significantly reduced. OcUK recommend a quality brand PSU for use with all our bundles such as the Corsair TX & HX range. Updating the BIOS on the overclocked bundle range will void the warranty on the overclock. If you update the BIOS we will no longer be able to provide support for configuring and maintaining the CPU overclock.
*Please allow between 24 and 48 hours for your system to be built and configured. This may take longer during busier periods.
Only £417.97 inc VAT.
ORDER NOW
"Krypton Z77 665i" Intel Core i5 3570K 3.40GHz @ 4.40GHz DDR3 Ivybridge Overclocked Bundle @ £473.98 inc VAT
Designed by experts the "Krypton Z77 665i Bundle" is a pre-configured high performance "plug and play" bundle featuring optimised settings. The Guaranteed 4.40GHz overclock has the processing power and speed unseen at this price point ever before. The "Krypton Z77 665i" will accelerate your computer experience into the next level.
- Motherboard: MSI Z77A-G43 Intel Z77 (Socket 1155) DDR3 Motherboard
Service Package
Only £473.98 inc VAT.
ORDER NOW
"Krypton Z77 670i" Intel Core i5 3570K 3.40GHz @ 4.40GHz DDR3 Ivybridge Overclocked Bundle @ £415.97 inc VAT
Designed by experts the "Krypton Z77 670i Bundle" is a pre-configured high performance "plug and play" bundle featuring optimised settings. The Guaranteed 4.40GHz overclock has the processing power and speed unseen at this price point ever before. The "Krypton Z77 670i" will accelerate your computer experience into the next level.
- Motherboard: Asus P8Z77-V LX Intel Z77 (Socket 1155) DDR3 Motherboard
Service Package
Only £415.97 inc VAT.
ORDER NOW
Don't forget these work well in x58 systems too and do very well, but always limited by the IMC
