PS3 .mkv to XXX converter?
23 Oct 2009
Derbyshire
Afternoon gent, got a movie i'd like to watch on the PS3 but it's in a .mkv format. Is there any free converters out there that are minimal in size and installation i.e I won't have to install and **** and can just run it as-is?
All the ones i'm getting from Google are wanting me to register and whatnot, Shirley there must be a free alternative out there somewhere? :confused:
Ta.
Got that MKV2VOB, anyone know any good setting to use so I don't lose quality while keeping the file size reasonable?
It shouldn't do anything to the quality, all it will do is change the file from an MKV to something the PS3 can play. Sometimes I do find that you need to select the "Use old file format" option if the PS3 is struggling to play the file (or shows it has having no length), but for the most part it just works as-is.
Ive just done one today using mkv2vob
Settings I used where video transcoding to automatic, transcoding codec to x264 (slow), output file extension to mpg, output type to file, always transcode dts ticked
File quality the same :)
