But if I made it exhaust air, there would be less air for the H80 to pull through?
Really? Less air? If you have 20 exhaust fans and only 1 intake there isn't less air inside the case, air is simply pulled through the intake at a higher rate.
Hot air rises, have your HDD fans intaking and your rear and roof exhausting.
So the H80 will definitely have COOLER air to pull/push through the radiator if the roof fan is exhausting the air within the case instead of inputting cool air into it?
You need at least as much cfm intake as exhaust... most prefer more in then exhaust with filters on intakes. If 2 exhausts and one intake means exhaust want more air then intake can supply... they compete with each other for available air.Originally Posted by Cythx View Post
