Corsair Air Series 120
The noise level is pretty high (?)
Sound Level 35 dBA
With a H80 it shouldn't run that loud? H80 sets speed based on temp. Any idea what dba stock H80 fans are? I can then get an idea.
Do I need to use the High Static Pressure with H80, if not I could go with there lower speed model.
Thanks
Comparing the stock H80 fans with the one posted, they dont seem much difference?
Fan Airflow H80 46 - 92 CFM / SP120 62.74 CFM
Fan dBA H80 22 - 39 / SP120 35 dBA
Fan Static Pressure H80 1.6 - 7.7mm/H20 / SP120 3.1 mm/H20
So based on that Is it really worth me doing? Doesn't look like but am no expert :D
