I hardly ever use mine. Only use it when the windows steam up, is not using the AC bad for the unit?
Always thought they use more fuel and eat up a bit of the engine power.
Why would there ever be a need to turn the AC off though? Just keep the thing on!
I think Kwik Fit charge in the region of £40?
I had mine done once as it was on a special at the local dealer
I thought the lubrication for the system was in the refrigerant so it was a good idea to make sure that the system doesn't run too low. No idea if that is accurate though.
