For the games you mentioned, these are the FPS readings I get on my Sapphire HD 7950 OC Edition with 1920x1080 at stock (all max settings):
Diablo III: 120-160FPS (this may have been with a small OC but definitely over 120) would imagine you would get at least 60-80
BF3: 50-70 depending on the scenes (I would say 30-45 for you)
Not sure about SW.
I'm considering a monitor upgrade but I don't fancy buying a 27" panel if my card isn't up for the task of driving it. I play SW:TOR mainly, but also play Diablo 3, BF3 and some other games.
My BF3 plays ok on ultra. Have not noticed any major slowdown and it certainly looks better than 23fps to me ?
Not at stock and not on 64 Player Gulf Of Oman.
I did a run-down in the following post, this question gets asked quite a lot.
http://forums.overclockers.co.uk/showpost.php?p=21781172&postcount=46
Seems fine to me and I play quite a lot. My card is at stock which is a slight overclock. Certainly nothing that has made me want to add another couple of GPU's.
I'm not bothered abut it being a constant 60fps as long as it plays ok..
Estimates are no use to me.Hence why I have estimates of your FPS next to my values.
Maybe you should have asked if anyone has experience with this rather than just flat out ask if it would be worth it when people who do not own this resolution are likely to reply.
I asked in my OP (thread title) if my card is enough to drive the res. One would assume that someone who has first hand experience of the combination would add to the topic, as a few people have done.
I didn't ask if it would be worth it at all.
Maybe you should read my OP and thread title before you try and flame me?![]()
