Living with a Nissan LEAF for 24hrs.
19 Oct 2002
Shakespeare’s County
On Tuesday I took the opportunity to take a Nissan Leaf on a 24hr test drive – Nissan’s ‘The big turn on’ campaign to get people into EVs. Basically I would pick the car up from the dealer in Birmingham and travel 30 miles to work. Plug in to charge up the battery at one of the EV charging stations on site and then 40 miles home.
Whilst the stickers do little for the cars image atleast its clear the car isn't mine.... my car is far uglier :D
The dealer were aware of the test after I booked and chose the day from the Nissan website around 2 weeks ago. 1 week before the drive they had also called to confirm the booking and this allowed me to check that the charge lead was included, some dealers had not been including them on the tests leaving people confused and going away without the car as they wouldn't be able to get it back to the dealer!
Starting the car is similar enough to a modern auto, foot on brake, press power, select gear, drive away. It even has auto park brake disengage when you drive away to save hassle. Of course pressing the accelerator makes little noise other than the hush of tyres so the handbrake disengaging is quite intrusive. Battery is full, range saying 93 miles we’re moving.
Plenty of options in the infotainment and incorporates additional EV content to what seems to be a Clarion core. Timing feature allow charge delay to make use of specific tarriffs, ie economy 7 aswell as preconditioning the cabin.
Weird, strange, bizarre and remarkably smooth are your first thoughts when you move away from rest, just the dull whir/whine of the motor and hushing of tyres. I have to say from that moment I was immediately impressed with the powertrain refinement, albeit expected being an EV. Nissan have evidently worked hard on the NVH as its not a tinny feeling car and has a feeling of robustness to everything underneath you. Looking down the range had tipped to 101miles. Obviously this is going to prove interesting how well it works as a range gauge or recent driving guessometric
The performance is excellent. The throttle response instant, I noticed a standing start will graduate power introduction whereas stepping on the throttle right into the pseudo kickdown switch at 15mph+ gives full power in an instant. The 1.5 ton car picks up at an impressive (for the class) pace. What you will notice in traffic is that the car and you sit much higher than a typical C segment car, (Focus,Golf,Astra). You are on the battery back between the front seat mounts and the trunk floor. Thumbs up so far.
Speed control is predictable and the overrun will generate braking energy back to the battery to mimic typical car engine braking. The car is single speed but does offer and ECO mode selected by moving the drive selector to D again where the cluster graphics change from a D to ECO. This seems to be much like a ‘sport’ mode on throttle by wire cars. It cuts back the power supplied for the given throttle position, essentially increase lower power resolution. Hold throttle at steady speed and change to eco and the car instantly starts to slow as power is cut. This seemed to increase the zen like state you get into driving cars that have minimal powertrain noise, not a new concept to me with my Insight but certainly another level in terms of incabin silence and refinement, so basically it dulls the throttle back which can be welcome as D can be quite peppy in how the car behaves. Either mode allows the full 80 kW when you depress to kickdown. ECO will also increase regen levels when you back off the throttle so ‘engine braking’ increases, this will go down to the full 30kW possible for regen when you press the brakes. Its kind of a hybrid between a bumper car and Ford Focus interms of information your brain is telling you! You know that low speed lugging and cold start quirks are attributes not relevant to EVs.
Ride is good if left a little challenged by the torsion beam rear. The roll control is very good thanks to the low batteries but there is no hiding the cars mass coupled with limited tyre grip, you can sense the car has momentum as the dampers seem to struggle a little on undulations mid bump, there is little in the way of feedback through the steering and the biggest oddity to me was the brake feel. Not a linear pedal, the car is always managing the blend between hydraulic brakes and regen and the pedal effort varies with that guess work. Rough road low speed braking likes to play cautious and any hint of wheel slip disables regen which suddenly means the car isn’t slowing like it was, easy to correct with more pedal effort but its like reaching into the pedal box of an unservo’d Elise at that point. Weird and something I would suggest Nissan work on to normalise the driving experience to an ICE.
Also only having rake adjust and not reach limits adjustment for driver comfort, tall drivers like me will no doubt lift the rake up which then means the steering column cowl shrouds the A/B trip reading…. Hows that for managing range anxiety?! Look round the column cowl a bit more and you will find the blanking plug for a key hole aswell, not sure which part this car has been carried over from.
So, round town, and in urban traffic its brilliant. I then hit the motorway…. And the racetrack that is the M40 at that! Joining the slip road and building speed was easy enough the acceleration does drop off as speed builds but its certainly not insufficient. Felt like the car needed to change up a gear as the whine increases in pitch, akin to joining a motorway in 3rd gear I guess, but you can only really hear it due to the wind noise being managed so well from the airflow guidance offered by the headlights.
The car has cruise control so I just stuck it at that at 72mph, economy gauge sat at 0.3kWh/mile which seemed okay and plenty of range to get back to work. Forward vision is challenged on the drivers corner thanks to the obscuration of the A pillar. 300kg of batteries upside down will put some extra requirements on meeting federal roll over roof crush though! Side mirrors are small, aero has no doubt had a hand in that so checking blind spots over your shoulder is important. It saved me from collecting a transit at one point!
Unfortunately I didn’t have the carwings working or enabled to allow comms with the iPhone app where you can preheat/cool the car on demand so instead set a climate timer for 15mins before I got back to the car…. Perfect to get into a conditioned cabin and for your sanity as a final check before you go to bed!
The cabin climate when driving is confusing though, it makes a guess at your range hit when you turn it on. Either the fans running with A/C off or everything on seems to give the same drop. Digital buttons are poor for HMI, not intuative and dont allow rapid change. I dont know why Nissan as avoided that as a degree of analogue control is such a bad thing even in an EV ;)
If you turn airflow off to recover that range then you get little in terms of cabin natural airflow through the car and then the wing mirror air management offered by the headlights seems to be good and discouraging air to come in through an open window! Pretty significant vanes! Digital buttons are poor for HMI, not intuative and dont allow rapid change. I dont know why Nissan as avoided that as a degree of analogue is such a bad thing in an EV ;)
I think running for a while will change the prediction the car makes and being able to ensure the heater is off is something you can’t really do. So I guess I should have checked that the temp demand was right down to make sure the heater doesn’t start pulling juice. I didn’t really use AC for much of the driving but turning it on seemed to peak the load at 1.5kW (ECO mode) so less than 10% of what the traction motor is using when your moving along. Of course that’s a totally different proposition in traffic.
For energy use information you can choose the screen to show what the energy in the car is doing.
I did 153miles over the two days. Topped up once at work to recover 33 miles, where 10kWh was put into the car from the post, I’m not sure how much went to the battery as the use would have included conditioning. I then drove 37miles home on that charge where I took this picture. With 37miles each way.... I could do it on charge when its warm weather.... winter would concern me.
At home I pay 9.2p/kWh so that’s in the region of 2.8p per mile with 15 miles at 72mph. I charged from 18miles range back to full (91 when I woke in 8 hours from a household socket) and then got to the dealer at 30miles.
Essentially to break that to simple terms a full charge will do 75miles with typical driving including ‘demo’ drives which tended to focus on performance of course. ‘Aren’t these slower than a normal car’ hmmmmmmmmmmmmmmmnnnnnnnnnnnnnnnnnnnn. ‘Not really no’.
The carwings average in the car was 0.24kWh/mile. So whatever you pay for electricity that will take you 4 miles and plugging in at home (10A) will give you 6miles for every hour plugged in.
Nissan will be launching the 2013 model, rumour is of a 6.6kW charger. So the current car SAE J1772 socket will allow 16A and is what I used at work, the update will allow 32A and match the charge time of the Ford Focus EV of ~ 4 hrs.
A more efficient heater is on the cars aswell, which could be a heat pump?
I looked at lease costs. £300 exVAT a month on a 6+23 business plan with 10k miles isn’t bad. Attractions of course are 100% write down in year 1 for a company fleet buyer and no tax for the user.
Overall I was very impressed with the car, more than comfortable for 4 adults and a proper sized boot with typical dynamics for a Nissan product in that class. Underneath its brilliant just the frock ontop spoils its attraction to Joe Bloggs I guess. The refinement is just not expected of the class and makes for a superbly relaxed drive with minimal effort whilst you chat on the Bluetooth integrated stereo in only a hum of tyre and whir of motor in the background, just don’t expect to have a desire to take it for a hoon down your local B road, there is minimal reward.
PICTURES:
The range needs to get up to 200 miles before I could consider one for business.
Looks promising.
Looks promising.
300 miles for me.
And it would be good if they could make the roof out of solar panal so that if you do go flat, the sun can charge enough in say 30mins to give you enough power to the nearest plug, albeit someone's house !
Nice write up but nothing can take away from that hideous nose. I'm with Ray as well they need a 300 mile range.
The only problem I can see with 300miles TODAY with tech is the car would be 2100kg tons not 1.5 and would cost ~£12k more. Im not sure if that would make it more attractive or not though.
Interesting read thanks, I really really like the idea of an electric car but it's the initial cost that's a bit prohibitive for me, I like the Twizy and is along the right lines for a commuter but not really suitable for British climes!
Using your figures the Leaf would be cheaper on fuel for me by a factor of about 3.5x!
My current fave is the volt/ampera so that the potential range makes it a primary car, but would like to see it with a better package i.e. more efficient engine (and obviously a lower price!) and would seriously consider it.
I actually saw one today on the road, at work we have an E Fluence plugged in aswell... That is a long car! Once they change the corsa engine in the Ampera its will be on its game. Problem is thats its another £200 on a business lease and 6% BIK.
Very good write up, shame you didn't have it longer to really see how it's like.
The lack of fast charging on the leaf is a massive downside, glad that's being improved in next model. But then again, it's only designed to be a city car.
I spoke to the dealer with a reasonable degree of conviction such that he went on to suggest it might be available for a weekend trial for me. Ill see how that pans out. Business use would only make sense for me on a 3+ deal @ £250.
Fast charging at the dealers is free but thats a £30k box.:p
What is the purpose of the under-bonnet battery?
12v buffer loads, ie electric windows and allows the HV battery to go 'cold' when parked. You can decouple the battery from the system harness by opening the main contactor and the car is still ready to drive.
Tesla have a design issue as they dont have this battery so long term low SoC can brick the battery by letting cells drop too far. Alarms, telematics, and dormant systems all use the HV battery rather than the more sensible 12V storage.
Thanks for the review. I find cars like the Leaf intriguing so it's interesting to hear what you thought in such depth. I really like the futuristic aspect of cars like this, they really feel like they are fundamentally different to traditional petrol or diesel cars.
It feels quite strange that this isn't a car I could just simply jump in and drive, but something where I need to read the manual and understand what all those icons on the dash mean.
I can see myself owning a hybrid or electric car such as this one day. Problem is they cost a fortune new and no one is really sure what the long term costs will be. I've heard all kinds of things about battery life and replacement costs so an uncertain second hand market, although this could just be hearsay.
Who knows if pure electric or hybrids are the way forward, maybe both, but it does feel like the traditional petrol or diesel engines might become a thing of the past or the wealthy.
As long as I don't have to perform a software update every time I need to go for a drive, or suffer the blue screen of death on the motorway then I might be interested in this in a few years, who knows. Do you think they can overclock? :D
Nice write up, sounded quiet on the handsfree kit, a guy at work also had one earlier this week and havent seen how his experience compares to yours.
I went in a Mini-E very briefly, like you say, you can feel the momentum. It has lots of 'engine braking' on lift off too.
The one major thing I see is who repairs it when it breaks? Not a single mechanic that I know of would have a clue where to start!
I would think the AA/RAC would be clueless too (since they will just call up a local mechanic anyway).
That is just not far enough, not nearly. If it only has that kind of range then you might as well make the car the size of a Fiat 500 as I would have no confidence of driving it cross country.
