SilverStone Raven RV03
10 Dec 2006
Hello guys
My latest case review sees me look at the RAVEN RV03. Here is my full verdict below, hope you like the review!
SilverStone RV03 // BUY @ OCUK HERE!
index.php
Thanks mate, yeah that'd of been a good idea especially as most don't use that bottom slot for GPU anyways and its making good use of space.
Thanks for the review I have been trawling the Internet watching vids and reading reviews for this case for a couple of weeks but didn't find a single review done by the use for the user. One question I do have is, do the hdd bays get to crazy temps under full load an of so how is this solved?
Given you can attach 120mm fans to the HDD bays, I don't think this is a problem, and the mountings in other parts are for 2.5" drives or SSDs.
Thanks! :) As Krooton says you can attach 120mm fans to those HDD bays to eliminate heat!
Yea the concern I had with the hdd bay fans was that they might interrupt air flow through the central spine of the case. If it comes with air penetrators as stock though I'm sure this wouldn't be a problem
this is the only raven case that I HATE, in order of how the cases look in the raven lineup, I personally would have it as, RV01, RV02, RV04, RV03 ;)
