I am looking at spending around £6K on a second hand car. The two candidate are a Merc SLK or a Mazda MX5.
As I see it, the true cost of buying a car is:
1. The cost of the car
2. The depreciation rate
3. The servicing costs
4. The MPG
With this in mind, I want to calculate whether the Merc or the Mazda is less expensive. Initial thoughts are that while the Merc servicing costs are higher, the depreciation on the Merc will be less (since the Mazda is cheaper when new, its likely to be on a faster depreciation rate at that stage).
Which do you think is cheaper?
Thanks,
Jon
4. The MPG
Thanks,
Jon
