Guys, quick Q about Vista/7 dual boot and how to remove one
31 Aug 2007
Guys, as title, just been handed a laptop that has Win7 and Vista on dual boot.
The system was initially Win7, but Vista was added as he was duped into thinking that Vista was needed to run a particular piece of software (which it wasn't :rolleyes:).
So, he wants me to remove Vista without touching the Win7 install, but I've not done that before.
From looking at the system it appears Vista has been installed in a seperate partition, as the Disk Management screen lists the following...
System Reserved 100MB NTFS Healthy (System Active, Primary Partition)
C: 206.42GB NTFS Healthy (Boot, Page File, Crash Dump, Primary Partition)
D: 26.37GB NTFS Healthy (Primary Partition)
Now, I know that C is the original Win7 install, and D is the new Vista install.
Is it simply a matter of deleting the partition with Vista on it, or is it not that simple?
Do I maybe need to use something like EasyBCD so that the boot ini file doesn't get stuffed?
Thanks
There is no boot.ini file, hence the BCD part of EasyBCD ;)
I'd back up the current BCD using EasyBCD, then edit out the entry for Vista. Then reboot anc check that you only have Win7 as a boot option (or no boot menu at all hopefully), then delete the old partition and extend C back into the empty space.
Thanks a lot. How would I extend C back? Is that easily done?
EDIT - found it, easy peasy. Thanks again for your help :)
