Blast From The Past
I loved my FreeSpeed Pro clocking card for my slot A athlon made my 650mhz do 800Mhz Awesome Speed increase for the day and age!!
I remember when Google didn't exist and it was all about the hotbot!
Yeah! I got online in 1998/9 and although Yahoo was the most dominant search engine, there were quite a few successful engines going back then. It was all about Altavista, Infoseek, Excite, Lycos, Ask Jeeves, Go.com... :-)
Nice find OP with the Wayback Machine. For some reason, my works computer blocks it because it thinks it's an "anonymiser site". Any idea what that's about?
I'm not sure if you're trying to be ironic or if you really do think no one else has posted this before.
Both of those examples are initialisms and the rules on whether you can use an apostrophe to signal a plural are debatable at best, some style guides recommend you use them and some don't but I don't think there is a definitive right or wrong.
I tend to not use one but the problem comes when you are writing in one case. If you are restricted to using uppercase for example then you kind of have to use and apostrophe to show the trailing 'S' isn't part of the initialism/acronym.
Debate it all you want, it's still incorrect.
