Best 670?
13 Dec 2008
Hey guys
So my card has died and i am replacing it with a 670 as that seems the best card in that price range.
My question is which do i go for? I dont really overclock graphics as they tend to run everything i want but i do still want the option and whatever else sets the cards apart. I was thinking of an EVGA Super Clocked as it was around £350.
Any others to look at? can price stretch a bit if its really worth it
Thanks!
http://www.techpowerup.com/reviews/ASUS/GeForce_GTX_670_Direct_Cu_II/1.html
10/10 here, there are other reviews around. The problem is that it's voltage is locked or something so isn't very good for overclocking, hence why the windforce is raved about here. Depends what you are wanting to do with it (overclock wise). If you don't want to overclock yourself then this is already overclocked at factory as faster than a 680 while getting very positive reviews for other factors such as temperature/noise level.
yea there seems to be argument for both with neither having a totally killer reason to pick it from my reading, other than i can get the TOP version of the Asus card with all the overclocks done. no idea about OCing the Windforce though
Gibbo got his to 1400 IIRC
