Iron Front: Liberation 1944 1.01a Beta
Dear Iron Front fans,
again we have some good news and some bad news.
The following beta version contains finally the dedicated server and fixes several major issues.
Unfortunately the beta cannot be used by STEAM users. In addition it contains an updated engine,
which is no longer backwards compatible.
This means in Multiplayer all beta users will be separate to 1.0, 1.01 and STEAM users.
We are fully aware that this is bad news for STEAM users and we are very sorry about it.
Unfortunately it is not without our possibilities to make this beta available to STEAM at this point.
With that said we hope to provide a full 1.02 update early next week to all owners of Iron Front.
We wanted to get this update out ASAP to enable most players a better game experience.
Please share your feedback and thoughts on forum.
Thank you for your attention and understanding.
Copyright (c) 2012 AWAR & X1software. All rights reserved.
BETA WARNING:
THIS UPDATE WILL MODIFY YOU EXISTING GAME INSTALLATION DIRECTORY. ROLLBACK TO PREVIOUS VERSION IS NOT POSSIBLE. THIS BETA AND FINAL UPDATE MAY DIFFER. AS ALWAYS, USE AT YOUR OWN RISK. THANK YOU FOR YOUR SUPPORT.
SYSTEM REQUIREMENTS
An original version of Iron Front: Liberation 1944 patch to version 1.01.
DOES NOT WORK WITH STEAM. PLEASE HAVE PATIENCE UNITL STEAM UPDATES. THIS MAY TAKE A FEW DAYS.
HOW TO INSTALL THE PATCH
- Download the correct beta version for your game version (DISK = DVD/Retail Version, ESP = Digitial Version).
- Backup the following files:
* .\Iron Front\ironfront.exe
* .\Iron Front\dta\bin.ifa
* .\Iron Front\dta\bin.ifa.liberation.bisign
* .\Iron Front\IF\addons\if_mpmissions.ifa
* .\Iron Front\IF\addons\if_mpmissions.ifa.liberation.bisig n
- Extract the files to your Iron Front directory.
- Please note that it is not possible to rollback to a previous version after the installation of this patch, only a full reinstall of the game is possible, if you want to keep your previous version you may want to backup the entire game installation folder before applying this patch.
Version 1.01a Beta Changelog
* New: Dedicated Server executable.
* Fixed: Server freeze on crashing players in multiplayer.
* Fixed: Various crashes.
* Fixed: Respawn in C&H missions.
* Fixed: Join-in-progress in C&H missions.
